The Astrolux mf05 (Does Size Really Matter) ?! Well that depends on your personal point of view. What is my point of view here you may ask? Well I don't know yet. (Yikes a little impatient arent we?) So if your interest is peaked please follow along with my humble little analysis(well really rantings)!
Having some time on my hands the other night,before the overnight shift at work and being inspired by my mentor, CPF'S famous flashlight reviewer, run4jc, I set out to quantify just what my view is
A viewpoint needs to be based on something discernable that I like to call "facts" or in today's World "alternative facts" if you Will.
Thankfully freeme has kindly provided us with some real World data, that I like to call "facts".
So just what are the facts? Well there a set of quatifiable measurements of the light. and here they are again for your perusal. Overall length is 426mm (16.77'") . bezzel o.d is 160 mm. And the battery Tube is 64 mm Wide were told.
Here's were the fun begins:
IFirst and foremost, I want to know just how fracking big the head is. It looks huge. am I right? But your Probably saying this guys nuts , because there's no way to measure it . And your right in thinking this, but what we can do is make a pretty good estimate, using Freeme's numbers and combining them with measurements garnered from the old compare and contrast magical method!
And all we need is a measuring tape and a similar flashlight( in this case the famous BLFgt light Will play the part quite well .let's dive right in. The problem is I need to know how long the dern battery tube is and I can"t measure it but I can measure the tube of the BLFgt. And since both lights use the same number and size of batteries , with presumably similar battery carriers both tubes should be similiar in size.
In this case the BLFgt tube is 134mm(5.26") give or take not including the thread length on both ends.
The tailcap which again is probably similiar in dimensions to the Astrolux is 28 mm in length (well the visible portion when screwed in anyway). Add it all up add you get 134mm (battery tube) + 28mm (tailcap)= 162mm . Drum roll please . Now the Astrolux mfo5 overall length is 426mm, So we have 426- 162= 264mm(10.39") of length left approximately for the head!
Wow I don't know about you guys but an approximately 10.4 inch head is huge in my book! And could mean a very front heavy light.
So just how much mass (weight) is aft of the head?
Welll similar battery tubes should have similar weight but
hold on here, the Astrolux Tube is approximately 10mm wider than the GT one. So another assumption (what my beloved wife used to say "be careful about making assumptions as they can make an a## out of you and me!) is in order here. If both models use the same size battery carriers then we could be looking at a battery tube with approximately a 9mm wall thickness. This would add some much needed weight to the rear of the light. Yikes I misplaced the rest of the weight measurements so...
To Be Continued
My conclusions;
At 3.4kg(7.49lbs) empty weight, the Astrolux MF05 is probably the heaviest production flashlight every made.
It has presumably the biggest head of any led based Production flashlight and as a consequence maybe extremely front heavy.
Maybe the tailcap has a puck of solid "lead"?
Size Really Does matter here.
And I'm in love , so I'm buying it regardless of logic.
What do you guys think?
