Galiphrey said:What's the rationale of using a Lux-III in the Baltic? Isn't a Lux-I more efficient at these low levels?
jeffb said:Sure would like to see pix!??
jeffb
xochi said:Uhhh, ya know, he was handed the phone when I began to ask technical questions, but I really don't know if he's an engineer or not. Maybe he just stayed at a Holiday Inn Express the night before . I certainly do get the impression that he hangs out there alot .
Grubbster said:I just ordered a Baltic in brass from Peak. The Baltic uses a TWOJ led and the same electronics as the Pacific. The head is smaller in size and they told me they are about the same size as a Matterhorn head, maybe slightly larger. You can also choose your drive level like the other models. I chose a high power which should be putting out about 110 candlepower. It uses a 17mm reflector (IMS?) which is cut down to 13mm and covered by a lens (plastic?). It has the same construction as the Pacific. The electronics screw in from behind. Should have a nice wide beam. The bodies that will be available are N cell, 2xN cell, AAA, and I think 2xAAA. I think all the bodies are currently available in HA and stainless. The brass just has the N cell available with the AAA bodies following in a couple of weeks.
You have to call Peak directly to order. They said the website will be updated in a few weeks. I am not even sure exactly what these things look like, but I know they will be keychain sized. I should get mine by the end of next week and I will post some pictures.
Same pricing structure as the Pacific. About $50 plus $10 for additional bodies. Slightly higher for stainless.ernsanada said:How much do the Baltic's cost?
If you are talking about the hearing aid size batteries, I don't think those are finished yet.brotherbob said:Where are the pictures of the LLR44 configuration?? I am getting desperate.
