If the beam shots had been at 500 M instead of 85 meters for example, the impression becomes reversed, in that the TK70 floods a good 300-400 meters really well, but, it doesn't reach out with much useful life past that. Past this range is where a search and rescue light like the SR90 is useful, where the TK70 is useless.
I do disaster response work, and I use BOTH of them. If its short range, I use the TK70, as the flood of light is great. If its long range, I use the SR90 because its beam can put a large hot spot on a distant target...and it still provides generous spill for intermediate and close range.
The TK70 on Tenergy Premium D Cells was rated at over 2,500 L during testing at Photon Fest 18, the SR90 was rated at only 1,350 L. The difference is that the TK70 uses those lumens in a less concentrated beam, for a floody throw, and the SR90 concentrates the beam for maximum throw. MOST of the SR90's lumens make it out to a distant target...whereas the TK70's lumens are spread out over a wider area, and are not concentrated enough to throw that far.
Somewhere around 300-400 meters, the TK70's lux fall off becomes apparent...and it becomes harder and harder to tell if you are resolving a man with firewood in his arms, or a firearm, etc. The SR90 tells you if its loaded...or a load.
