My wife got a SureFire Fury-DFT light and a StreamLight ProTac HL5-X light last year for Christmas.
I have a couple of questions regarding batteries for these lights.
I currently have the following 18650 batteries:
I currently use either the SureFire SF2R or a NiteCore D4 charger to recharge the batteries.
In the StreamLight my wife is getting about 5 days of use with any of the brands of batteries (only using 2 of the same brand, not mixing them). This is using the light 2-3 times per night for 10-15 minutes at a time.
My questions are:
1) I would like to have 1 brand/model of 18650 battery that will work in both lights.
2) The StreamLight ProTac HL5X uses 2 18650 batteries.
3) Is there anything that I am missing or should be concerned with or aware of when using 18650 batteries with these lights?
Thanks,
Eric
- StreamLight Part #:220115 - 2600mAH, 3.7v, 9.62 Wh, (1 year old) with a USB charging port on the batteries
- SureFire L18650-1SF 60-03-021 Rev A. - 3.7v, 3400mAh, 12.58 Wh (1 year old) without a USB charging port
- Nitecore NL189 - 3400mAh, 3.7v (3 years old)
My questions are:
All 3 brand/models of batteries above work in the StreamLight HL5x.
Neither the StreamLight nor the NiteCore batteries batteries work in the SureFire light.
When I first got the Fury, the batteries it came with did not work with the light nor did the other 2 that I have.
When I called SureFire they said that the light required a Hight Discharge (I think, it was a year ago) and that neither of the other 2 batteries I had would work with the light.
My question is what is the best brand/make/mAh batteries should I purchase that will:
1) Be usable in either light
2) Last the longest in terms of light usage and charging cycles
I have 2 of the StreamLight batteries, 3 of the NiteCore batteries and 3 of the SureFire batteries.
I read on these forums that I should only use matching batteries, so I understand that I should only use each brand together and not mix them.
My question is since I have 3 of the NiteCore and SureFire batteries, should I rotate them when they are changed (about every 5 days) to keep all 3 batteries in a similar state due to charge/discharge or should I designate 2 for the light and only use them together and take the 3rd one out of the rotation?
Thanks,
Eric
