KiwiMark
Are iCharger a Kiwi company? I might get one eventually... Is there a kind that can just plug into a normal power point?
Nah, we don't really do any electronics manufacturing here - they're probably made in China like everything else (including Apple iPhones). The iCharger is a better quality charger than the cheaper ones though and has better features and a better UI - I find it easier to use than my Turnigy charger.
Normal power isn't too much of a problem, you can buy a power adapter for ~$10 that will work pretty well. I have a computer PSU that easily runs 2 hobby chargers that worked out to be the cheapest option. You can also buy power adapters like this one: http://www.hobbyking.com/hobbyking/store/__9205__25A_14v_DC_Power_Supply_for_Chargers_350W_.html that will supply up to 350W, so you can use the charger to it's limits. The cheap $10 power adapters are usually ~60W which works fine as long as you don't try to charge 6 cells @ 10A (I usually charge 1 cell at 1A which only needs 4.2W).
I bought this: http://www.hobbyking.com/hobbyking/store/__6792__iCharger_106B_plus_250W_6s_Balance_Charger.html
Even with shipping it was under $100 for me.
There are power adapters like this: http://www.hobbyking.com/hobbyking/store/__6477__IMAX_Power_Supply_100_240v_5A.html
One of these should be all you need. They don't seem to have stock currently, but I'm sure you could hunt around and find the same sort of thing elsewhere.
Here is a quick Ebay search: http://shop.ebay.com/i.html?_from=R...ower+adapter+12V+5A&_sacat=See-All-Categories
Having the power adapter separate from the charger means less heat in the charger and also if the power adapter fails you can replace it easily without having to buy a whole new charger.
