HIDC
Banned
Tried Nexcell 9000mAH. Complete garbage from Thomas Distrib. They took care of it well though. Instead, I ordered in a bunch of 2AA->D adapters and that works well in the TK70 for playing.
How long does the TK70 run on turbo exactly? On the TK70 thread a user gets an hour on turbo with the Imedion D cells. They might be LSD but that's interesting you get about an hour too on the 8000 mah Tenergys.
I thought that in tests, the Imedions DID have around their rated capacity of 9,5000 mah. Under heavy load like with the TK70 it may be a little different, but for something with less of a heavy load they are good. In another thread, a user did get an hour runtime with the Imedions, did you get an hour with the Tenergy Centura?
The Tenergy Centura is 8,000 mah rated, but the Tenergy Permiums are not LSD and rated at 10,000 mah.
I went with the Centuras based on 357mag1's testing comments and i am a happy camper! They hold great amounts of power! :thumbsup:
JD
The Centuras are LSD.
From the testing I've done so far even after 6 weeks on the shelf the Tenergy Premium cells still have over 9000mah of energy which is more than any of the LSD cells have fresh from my testing.
So it would really depend on how long you will leave them setting in a light.
Check novaeproducts.com for 32650 cells. They actually measure 70mm long and two power the TK70 fine. I just made a space to take up the extra room. All of my Novae cells tested over 5500mah after one cycle so they are fairly rated.
If you had a leak Nimh batteries would be safer than Lithium.
Wait, you have the Novae 32650 cells? And you tested them in your TK70? Another user mentioned that he had those Novae batteries and on turbo his TK70 would stop working (because of the protection circuits I presume). I asked for more information and if he tested those batteries elsewhere, thinking maybe one of them was bad.
I was really disappointed because I thought I finally found 32650s for the TK70 so I could still use the 3D tube and have a lighter flashlight vs having the longer and heavier 4D tube.
Can you confirm you got the Novae 32650s to work in your TK70 on turbo mode? And if so, what was the runtime?
Your reply to my quote might have gotten deleted by accident or something
Wow that's good news! Maybe the other user had a problem with one of his batteries and that's why they didn't work.
Could you perhaps try a runtime test with your TK70 on turbo mode and see how long it takes until the protection circuits kick in and the light turns off? You could submerge half the TK70 in cool water or something so the light doesn't get very hot. THat's what I've done with all my Fenix lights when doing runtime tests on my Eneloop and Imedion AAs, and 18650s. The lights are cool to the touch in the water once the light kicks down to a lesser mode.
If you actually get about an hour runtime on the Novae batteries I'll pull the trigger for a TK70 and those batteries ASAP. I'll have to make an adapter to charge the Novae 32650s in my PIla IBC charger.
I put Imedion cells from Lighthound in my TK70 after using some old, cheap rechargeables. The Imedion cells are wonderful. They last a long time, and they don't lose much energy after storing them for awhile. The Imedion cells brought new life to my TK70. It's a new light again. I use a Maha charger.
Unfortunately I don't have time to babysit the light to see when it kicks off the Turbo mode.
I don't want to buy these cells and have the light kick down from turbo to high in anything less than 35 minutes at least.
