ledmitter_nli
- Joined
- Jun 4, 2012
- Messages
- 1,433
Oh, and not to take away from the exhaustive and comprehensive setup shown by ledmitter_nli!
That's just cool. :thumbsup:
I just try my best. Thanks!
I also wonder what OP means by SHTF. Because If faced with SHTF in an EXTREME sense your flashlight situation would have many viable options and be an inexpensive piece of the puzzle. Long storage food packets (expensive) and heat are HUGE obstacles! I consider the flashlight situation in SHTF almost as easy as your clothes situation (EASY). Almost unworthy of being in the SHTF conversation it's so easy. Food, far from easy
Agree. Id rather have a fishing rod or my speargun than a flashlight in a shtf situation. Mankind have survived for ages with no flashlight. Not so long with no food
I agree... types of scenarios can vary greatly, and determine what kind of equipment would best serve the need/s.A simple magnifying glass works a lot better than a light's reflector if using the sun to start a fire...ask any number of historically popped ants, etc.
So, as pointed out, its a good idea to decide WHAT scenario(s) you are prepping for...and think about factors such as how portable and durable your stuff needs to be, and if a radiation or toxin issue might be involved (No steripen/boiling solution there), so that a still would be needed for clean/less deadly water, and so forth. Are you expecting ZOMBIES? Please don't, its fun, but unlikely enough that I think we can slip that one...and it can skew your prep in non-productive ways.
Than for SHTF all I would care about is the best runtime. But still for SHTF i'm way more concerned about my battery situation. In SHTF i'm totally unprepaired and screwed! Flashlight is about #150 on my SHTF check list, i'll be dead in a SHTF week hahaMy SHTF light is a 6P with A19 extender, housing a Malkoff M61. I keep the extender attached, with a dummy cell, running 2x123's. This gives me full output of 235 lumens. However, I can do two other things: run 2xAA for decent, long running output, or remove the A19 and run 1x123 with the dummy cell, with reduced output and extending the useful life of my batteries.
OP asked specifically about a SHTF flashlight, not about the basic necessities for survival. I find it appropriate conversation given this is a flashlight forum.
I'm sure there's a watch forum somewhere, where people are discussing the ultimate SHTF watch.
What features make a good SHTF/survival light? And what flashlight do you think best fits this description? Optional: What batteries would you use in this flashlight?
Multimode 3D sized custom Maglite running LSD NiMHs, robust and invaluable as an impromptu impact device, D cells are common if it comes down to scrounging over a long term basis, realistically you would want to be limiting your use of a torch/flashlight depending on the situation as to not attract unwanted attention.
Hell you could even use it for signalling (should the situation warrant) long after mobile phones and other comm's devices have become less than useless...
Just remove the protection board in the- end, and voila, you got a unprotected cell.I imagine that you could use the same techniques to start a fire with a 18650 battery, but what if it is a PROTECTED battery?
Post #2, Jetbeam PA40 and post #3, Fenix LD41...........are pretty much the same. I love my Jetbeam PA40.
I think any light will work for SHTF scenario as long as it uses rechargeable batteries. And as long as the light you pick has a few modes so that you can turn it down and conserve battery power. For that reason AA lights and Eneloop rechargeables are proabably the simplest to deal with. You may also want a single AA light too (backup?) or easy pocket carry.
The question then boils down to how to get the batteries recharged if the power stays out for a long time. Personally I have a LaCrosse BC-700 charger and an adapter that converts 12v down to the 3v that the charger uses. That way any solar or vehicle power will keep me going. There are also some USB type of chargers and you can always get a 12v to usb adapter.
