Edit of my earlier edit: the XP-G warm white emitter works fine. What didn't cut the mustard was my lousy soldering on the positive lead. After I took the lantern apart and discovered this, I resoldered the lead--doing a much better job--and now the Apollo shines with perfect, warm light. I've run it at max for 65 minutes, no problems.
I hope I didn't dissuade folks from trying this particular emitter swap, apologies if I led you astray.
<DISREGARD!>Edit: In real-world use, the heat sinking on the BD Apollo wasn't sufficient for the XP-G. My XP-G went poof after about 30 minutes of use on high
Back to the drawing board.</DISREGARD!>
I also modded this lantern, I used a 20mm Indus star with a warm white XP-G from LED Supply. You have to clip one edge of the star to get it to fit but it works great once it's epoxied on, and not too much trouble to center.
Three bits of advice:
(1) don't mess with the screws just under the battery compartment lid, all they do is hold the legs on and they're really easy to strip out. The screws you want are at the bottom of the battery compartment. I took off the screws on the top of the globe also, so that I could handle the reflector separately and test the centering of the star before I epoxied.
(2) the wires from the PCB are really delicate, go easy with them. I broke one and had to solder in a replacement.
(3) leave a bit of the plastic posts that retained the original square LED mount, they help hold the heat sink in position. But you need to trim them down so that the surface of the heat sink is flush.
I love LOVE this lantern with a warm tint :thumbsup:
