Boring service for Surefire and other aluminum or titanium lights
Henk_Lu
Golden Cage
Re: Boring service for Surefire® and other aluminum or titanium lights
wrong thread, sorry... :eek:
precisionworks
Benton Illinois
That's a good question. Can you describe how the Gen6 is different from prior L1 models? Here's some info posted in the "old" and now closed boring thread, perhaps that may help:
When SF manufactures this model, they bore in from each end & leave a centralized partition (or tube divider) which works fine for 1XCR123 ... but doesn't allow using a 17670 or 2XCR123.
SF installs a brass sleeve at the tail end, similar to the stainless sleeve in a U2 except that the brass is dead soft & easy to bore through:
The L1 is now ready for more power:
BenChiew
Malaysia/Ship to Portland, Oregon
I am not sure what the internal differences are between the various generations. Would someone knowledgeable chime in please.
I just wanted to know if I can bore my stock standard L1 from the Gen 6 Cree to take a higher capacity 17670 battery.
Thanks.
precisionworks
Benton Illinois
Found these images in an old For Sale thread in The Marketplace:
L1 Gen6 on left L1 Gen5 on right
Image-9853934-164840476-2-Web_0_e2715a2e2cf814f72597159b9fa30a1d_1
If there's enough length left to accommodate a battery 67mm long then yes, it can be bored. IIRC the Gen5 & Gen4 are both the same "longer" length and the Gen6, Gen3 and Gen2 are all the same shorter length. But I do not know which one is shown in the prior images.
PCC
Sitting' on the dock o' The Bay...
The Gen6 L1 can accommodate a battery of about 48mm long after boring. An 18500 did not fit afterwards.
I need to make arrangements to send you an M4 to be bored for 18650s. PM incoming.
precisionworks
Benton Illinois
That is great information to have, TYVM :thumbsup:
If I understand this correctly only the Gen4 & Gen5 have the length needed for 18500/17670.
A pair of 18650's and the Malkoff or Nailbender tower would be a really sick light :)
tobrien
Georgia Highway 441
the precisionworks link "PM's are disabled so please click on the "contact" page at www.PrecisionWorks"
is missing an 'm' when you click on the URL. ;)
also I'm about to hit y'all up through the precisionworks.com page :)
thank you!
precisionworks
Benton Illinois
thank you!
Thanks for the heads up. I'll contact the site admin & have it corrected.
PoliceScannerMan
Gainesville,FL
Mike, your light is done :)
Surefire E1E bored for 18350 ...
Image-9853934-154551180-2-Web_0_91420c875c5d6690b20923ff87ca79be_1
Image-9853934-154551182-2-Web_0_d4fb347f45de335bcd2c0752eb532de5_1
Battery tube is first bored to near net size & then reamed to 18.50mm (.7283"). Bore is then refined with a 300 grit ball hone, followed by 600 grit, and finished with 1200 grit. Honing opens up the bore to 18.52mm (.7290"). The 18mm test cells will just slide into the bore without binding but there is no wiggle room - this leaves the wall thickness as great as possible.
Hi, I have a project, can you do the above on my E1e body? How much?? :D
PoliceScannerMan
Gainesville,FL
Certainly, $48 for boring & $6 return shipping.
Perfect, I'm most definitely going to do it. Can I just ship to the addy on your website?
I will confirm before shipping, looking to ship to you in the next week or so.
Thanks Barry! Still loving my 3P you bored for me. ;)
samuraishot
NY
Hi Barry, I just received a bored E2e from a member who had it done by you - I just wanted to say that I love your work!
knguye11
Hi,
I have three Surefire LX2, L4 and E2L and would like to bore out for AW18650. Is this possible?
Thanks,
Kyle
