Re: Going to Build an Aleph LE; My First Real Mod!
You may have had a component shift when you soldered the board to the can. It would be easy to do if the can moved before it cooled completely.
40 watts is the bare minimum. I have a simple analog
60 watt temperature controlled soldering station from Circuit Specialists. It works fantastic, and is a good value. I use 0.031" diameter
Kester rosin core solder, with some solder flux that I get from Radio Shack. I tin the pads of the MCPCB before it is installed in the light engine. After the light engine is assembled and the leads are trimmed to length, strip the ends and pre-tin the wires. To connect the leads, I apply some flux to the pads with a tooth pick, and hold the wire to the pad with tweezers. I touch the tip of the iron to the solder, wetting the tip, and contact the solder joint and wire. In a few seconds, the solder flows smoothly over the connection. Remove the tip of the iron, and let it cool before removing the tweezers.
An underpowered soldering iron will take too long to make a connection, and will produce rough looking solder joints. A solder joint should take about 2, to 3 seconds if the tip is hot enough. Sometimes a well sinked copper MCPCB may take a couple of seconds longer. Maybe 5 seconds, at most. Another tip that I will pass along which may be helpful: I bend the tip of my soldering iron. When it is heated up at the highest setting, I work the tip into a 90 curve shape. This allows me to solder with the iron being at nearly any angle. I can use the point, or a larger section of the tip to heat a connection. It is also good for working around other components, or in the head of a light that has not been fully disassembled.
Regarding the helping hands. I gave up on the alligator clips many years ago. They don't hold
anything well, are hard to position and very unstable. I purchased a
GRS double third hand, and never looked back. I got mine for about $100, including shipping and it was worth every penny. When I grip something to solder, it stays in place. The tips are removable for cleaning, and solder won't stick to them. Another tool that is really useful for building light engines and general flashlight work is a
jeweler's peg clamp. They can be found on e-Bay for cheap, too. Cut off the base with a hack saw, and it will rest flat on your work bench. It will clamp the light engine or flashlight head easily, and makes soldering much easier. Don't clamp too tight, or it will leave a mark.
