HotWire
- Joined
- Mar 9, 2011
- Messages
- 1,651
You won't go wrong with Energizer lithiums. They will power a remote for a long time and they won't ruin your remote by leaking.
Actually they have a no load voltage new of 1.8V or so. I've measured 1.83v on some I got. That is about 20% higher than ~1.5v cells.The Energizer Lithium AA/AAA batteries have a full-charge voltage of 1.7v. It's not enough of a difference to damage (almost all) circuitry, but it's enough to give most devices a nice kick in the pants.
I measured 1.7v on mine. A tenth of a volt is probably safe to write-off as being a statistical error between our voltmeters.Actually they have a no load voltage new of 1.8V or so. I've measured 1.83v on some I got. That is about 20% higher than ~1.5v cells.
A smart charger is a charger that stops charging every few seconds so it can measure the charge in the battery, so it can stop charging when the battery reaches full voltage.Explain the smart charger comment to me please
Guiri,
Do you know what type of alarm you have? Is it something similar to the Viper 5901 that will alert you when the car has been broken into? With the 5901 your remote is kinda shaped like a little pager. It's a transmitter and a receiver. When someone pry's open your driver side rear door, it tells you someone pried open your driver side rear door, etc.
I'm just curious what car remote uses so much juice.
We're saying the same thing.That was a new definition of a smart charger. I would usual define it as one that has independent channels and uses -dv/dt as primary termination.
