<font size="2" face="Verdana, Arial">Tis true. But they cycle them before they even install them. Only way to make sure everything is at spec capacity, etc. Nobody has noticed any increase of range on the new Rav4's.</font><hr /></blockquote><font size="2" face="Verdana, Arial">The same thing is done with the higher performance engines. They break it in at the factory. I'd bet that the synthetic oil goes into the engine after this is done. Only takes a couple of WOT pulls to mostly break an engine in.Originally posted by darell:
</font><blockquote><font size="1" face="Verdana, Arial">quote:</font><hr /><font size="2" face="Verdana, Arial">Originally posted by Saaby:
but LiIon and NiMh batteries like to be cycled a time or 2 boefore they're up to snuff. Minimal break in, but break in nonetheless.
<font size="2" face="Verdana, Arial">This implies that Joe six-pack actually pays ANY attention to what the mfg recommends. I find that simply not to be the case. I just can't imagine Joe basing his decision between a Licoln Navigator and a Ford Excursion on break-in miles.Originally posted by Minjin:
if given a choice between a car company that specifies a 5k mile break-in (where consumer should avoid abusing car) and a car company that states no break-in, they'll choose the latter. Consumers are lazy...
<font size="2" face="Verdana, Arial">That's my dad. Pretty bad when you have to pass up valet parking because the valet won't know the trick to start the car (happened to me).Your typical driver doesn't care what gasoline octane number is recommended, what oil change intervals are suggested, what tire pressure to use, or the best way to break in an engine. It is a rare automobile purchaser who takes any of those items into consideration when making a purchase.
<font size="2" face="Verdana, Arial">Hmmmm...hadn't heard that. Maybe your $5000000000000000000 Porches but certainly not "lower high performance" engines like those found in your common every day BMW, Saab, or Audi. What I know is that it would be a logistical nightmare to drive every new BMW 6000 miles before delivery--and who wants to pay $70,000 for a car with 6,000 miles on the clock anyway? I do know this is true with really really high performance cars-- (the kind you and I will probably never drive) BMW uses engine blocks with about 60,000 "civilian" miles on them for their race cars. Get better performance out of them and less likely to crack on them. That's nothing like a Ford Taurus or Dodge Viper...The same thing is done with the higher performance engines. They break it in at the factory.
[qb]if given a choice between a car company that specifies a 5k mile break-in (where consumer should avoid abusing car) and a car company that states no break-in, they'll choose the latter. Consumers are lazy...
I never implied that people actually base their purchase on something as mundane as engine break-in time. Instead, I was just pointing out that people would prefer anything that requires less effort. Even if the manufacturer would love for you to go easy on the car, they won't print it because it may seem to the consumer to be a hassle.
And of course, the hotter the oil is, the more it hurts when it sprays on you but the faster it drains. Therefore more cars can be done in less time, therefore more money.
Mark
<font size="2" face="Verdana, Arial">Hmmmm...hadn't heard that. Maybe your $5000000000000000000 Porches but certainly not "lower high performance" engines like those found in your common every day BMW, Saab, or Audi. What I know is that it would be a logistical nightmare to drive every new BMW 6000 miles before delivery--and who wants to pay $70,000 for a car with 6,000 miles on the clock anyway? I do know this is true with really really high performance cars-- (the kind you and I will probably never drive) BMW uses engine blocks with about 60,000 "civilian" miles on them for their race cars.The same thing is done with the higher performance engines. They break it in at the factory.
As I mentioned above, most of the engine break-in is done with a couple WOT pulls. A good ten minutes or so. Its a simple matter for an auto manufacturer to do this on an engine dyno to ensure proper operation while breaking it in at the same time.
And in reference to your comment, yes BMW does do this for some of their vehicles.
As for using engine blocks with higher miles, the more heat cycles its seen, the tougher the block becomes. Drag racers will do the same thing by using their blocks in their tow vehicles for a season or two. This has nothing to do with the engine break-in as pertaining to ring/cylinder wall interface or bearing surfaces, but rather the metal of the block itself becoming altered over time.
Mark
<font size="2" face="Verdana, Arial">Thanks, I'll get some WIX for my car. I just picked up four OEM Oil filters from a friend at Toyota yesterday ($3.85 each) for my other car.Originally posted by Light-Headed:
Hey axolotls,
I posted up above about my dad being an auto mechanic for over 40 years and he highly recommends WIX filters which is what I'm using now. They have a nice website with an area called "where to buy". You can enter your zip code there and it can guide you to the nearest locations that stock them. Hope that helps.http://www.wixfilters.com/
<font size="2" face="Verdana, Arial">This is true, but only to a point. The knock sensors will rein in any detonation and adjust accordingly. For high octane use, though, the KS will simply "top out" at whatever the programmed computer setting is. If a motor can reach the pre-programmed max settings, say 34° of total advance at 3000 rpm with 87 octane, then feeding the car 92 won't have any benefits.Originally posted by Minjin:
Oh yeah, almost forgot about octane. Many modern cars WILL see a performance increase from a higher octane gas.
Mark
<font size="2" face="Verdana, Arial">Originally posted by axolotls:
<font size="2" face="Verdana, Arial">Looks like I'm going to have to contact WIX and ask them to start paying me.Originally posted by JackBlades:
I'm going out to find me a WIX filter today.
