I wasn't specifically talking about crushing, but certainly the very first link you found would have been this backhoe crush test. There certainly was smoke. The next prominent link was the results of a disassembled A123 from an RC airplane. Hard to say what happened there. The next link I found was a investigation for a Prius fire containing A123 cells that caught fire.
LifePO4 and specifically A123 cells do not vent with flame as others, I never said they do. That's why they are safER. But they can have the same dangerous chemical reaction as other cells and once it's started there is no putting it out. The energy from this reaction must go somewhere. The battery is a steel can. It will build pressure and explode. Luckily there are pressure vents as a safety precaution. Unfortunately they don't do much good when the battery is in a liquid tight tube with an led at one end.
I am not going to spend any more time with this, I will only point out one more time, it is incorrect to make a blanket statement that there is no possibility of accidents with an A123 cell. There is ALWAYS the possibility of accidents. Instead, it's up to the well informed consumer to weigh the pros and cons of each system and make his own choice.
