Re: all LED PR flange drop-in bulbs.....?
Hondo,
Good points! I've added the EverLED Diamond Lantern version to the list.
Careful, 6V lantern batteries are center spring NEGATIVE. Everled has a special bulb for this, but most are center positive. Best case is it won't work. For sure, the Sears Craftsman LED upgrade bulb will blow if installed in one of these, and it shows one right on the package as a candidate for the upgrade!
I made my own center positive, Li-Ion rechargable lantern battery for this bulb by seperating the top of a cheap carbon battery and replacing the cells with four parallel 26650 Li-Ion's, wired positive to center. You can fit up to eight 18650's in there, BTW. Or just re-wire the existing cells if it is not dead, or replace with four alkaline D's. But in my experience, re-wiring the battery is easier than trying to reverse the light. Don't try this with alkaline 6V batteries, once you peel the steel can you have a pile of loose junk. I used a shop knife in the parting seam of the plastic lid, near the corners, and whacked it with a hammer, working my way around untill the whole thing broke free. A little hot glue to hold it back on when done.
Hondo
Hondo,
