Ark, APC stands for Automatic Power Control. It is a Photo Diode that measures the output and automatically adjusts it for constant, no fluctuation output.
I have now confirmed that disableing the APC does indeed increase the output dramatically.
Just cut both wires off, you will no longer need either. Unless you intend on using APC at some point.
The output after APC disable is 54mW @ 397mA. Again using LED method, so theres error here.
I have not operated it for more than 15 sec. with no APC yet.
BTW, I removed my module by using a mini pipe cutter about 3/8 in. back from where the tip goes on. The module slid out very neatly and this allows me to slide it back into the housing to use it as a pointer. A piece of tape holds it nicely in place.
I also disassembled the module itself. There is a beam splitter that directs output to the PD. I will remove the splitter soon to see what effect it has. It is green in color so I will assume it is also used as an IR filter. Removing it will let more IR through. It should also increase the output slightly as part of the output is being split and directed to the PD.
More to come...........
