It was not dropped. There was a green filter (brewster?) plate on the front feeding the feedback APC diode - that came off after I damaged the other stuff (basically contained in about 3 mm's of space surrounded by a bronze circular ring) situated behind the pass-through / brewster window. In this 3mm's was a white-ish crystalline substance and a small green fleck of something - thin and a perfect oblong shape.
Just before this the laser was working fine but low power. It may still have been working but giving out IR of 808nm or thereabouts - too dangerous to keep in this mode. I had unscrewed the laser assembly (one brass section unscrewed from the other) many times and replaced it and it still gave a bright output. It only failed when I probed the wrong place.
This particular laser may not be the best to go for in terms of modding. Some pcb's may be different from others even if the lasers all look the same (Ebay is full of this type of black/silver model at present - some even call it a leadlight but it's not). No difference with APC disabled nor pot twiddling (btw - the wiper and the left side of the pot were shorted on my pcb).
