Here is a tip, DO NOT DO THE STAGE 2 mod for these NewWish lasers, expecially the one Sputnik pictured. The diode is already aligned as best it can, if you unscrew it YOU WILL NOT be able to get the same beam ever, unless you have special tools or just get really really lucky.
The REASON is that the diode is smaller than it should be, it has space when inside the thingy and if you remove it it will be almost impossible to have it centered. I've tried thermal paste to keep it moving smooth, NOTHING HELPS, I've had a good beam however it has some spill, so you know that it will never be as good as it was before. I must have spent 10+ hours trying to realign it and I got it back in the spot once only to remove it again thinking I can get it better, but no way, didn't happen again...
Also i'm thinking that if you mess around it it unaligned it will damage the diode or crystals because when not aligned I would get an extremely bright beam and then it would dim out... So there ya go, I should have just gotten the leadlights to begin with... I also did the pot mod on this one and the beam got dimmer just a little bit than stock, so it didn't seem to work on mine. I had 3 tries and only 1 made a brighter beam, the first laser with bad divergence... I may only try to short the pot to see if that helps with the last unmodified one...
