Phlogiston
A new Convoy S2+ tidbit: apparently, it uses 4.5kHz PWM, which is a decently high frequency that most people won't notice. That's from a BLF post by ToyKeeper, who is a well-respected firmware programmer and presumably has first hand knowledge.
Cool, I hadn't heard about that yet. Where did you find out?
As far as I know, the only difference is the metal button versus the rubber switch boot. I wouldn't mind seeing the black and grey S2+ models offered with the metal button as well.
Note that the metal button may not be as water-resistant as the rubber switch boot (BLF post by J-Dub74). The metal cap has to slide in a tube to operate the switch, which means that there's a sliding interface where water could get through, unless there's a rubber seal underneath. In contrast, a rubber boot simply deforms without ever allowing an entry route for water.
I'm tempted to take one of my S2+ Red tailcaps apart now, to see if there is a rubber seal under the metal cap, but it's not going to happen until my spare gets here. Any takers in the meantime?
Thank you both, and everyone who's expressed support for this thread :thumbsup:
There's a green S2+ version in the pipeline as well.
Do you know if there's any other differences between the different colour models than the button type?
Excellent post on the comparison table.
Contemplating to get some S2+ myself and the information you provided is awesome and very helpful to chose right.
Thanks a lot Phlogiston! :twothumbs
