OK, so now that I am caught-up from my sales thread on
custom Delrin parts for the V10R/V11R, I have been able to spend some time on the my Joule Thief's characterization on very low currents
I started by building 6x test boards with various inductor values - here are 4x of them:
And then I tested with my normal target (3Watt Luxeon), but also with a 5mm and 3mm white LED (both 20mA rated):
My standard Joule Thief has a default inductor value of 4.7uH, so I tried inductors values of: 22uH, 33uF, 47uH, 100uF, 220uH, 470uH, and 1000uH (1mH), at voltages in between 1.5 and 3.5 volts (to simulate 1xAA, 2xAA, and 1xCR123, and a little above 3V to know some more - I am always curious like most of you!). Out of these tests today:
- for single AA cell, the 22uH gives between 14-15mA for the 5/3mm LED's, so a value of about of slightly less than 22uH will give you the 20mA, but with 22uH you have some headroom, so this is about perfect to account for part to part variability.
- for 2xAA cells, or 1x CR123 cell (3.0 volts), the 1000uH (1mH) gave 9-10mA, but at 3.4 volts (like with two Energizer Lithium AA's) I got 19mA, so it looks like 1mH is the ideal value for two AA cells (of any type), or a single CR123.
Will
