Toohotruk
I'm curious how well the 4 Sevens batteries do compared with Battery Station (USA) cells...
The NiteCore EX10 Med/Hi run is at about the same output as 60-85 lumens on the Novatac, so that should give you a general idea. But the Novatac has a fairly specific step-down pattern, so it would be difficult to say with any certainty without testing it.How well do they work/compare on a medium draw light?
Like my Novatac on 60-80% brightness setting.
Based on my limited testing of one batch of Battery Station cells in my CR123A Round-up thread, their performance appears comparable to Energizer or Rayovac - once adjusted for sample age.I'm curious how well the 4 Sevens batteries do compared with Battery Station (USA) cells...
Interesting question, I hadn't heard of that before. I think I can dispel it, at least for Energizer CR123A cells (may be different for cheapo foreign cells).In the early days of CPF some members believed that cr123 auto-discharge accelerated significantly after even the briefest use. You could use your light for a minute and store it in the glove compartment, and after a week the battery was dead or near death. The idea was that a new cell had some kind of physical protection against rapid self-depletion but as soon as the cell was used that protection (some called it a kind of "membrane"), was in effect breached.
Have you ever heard of this phenomenon, and if so is there any truth to it?
The issue may have originally come up because what seemed to be an inordinate number of Surefire cells were dying after brief use. Whatever the cause, I haven't seen the issue raised in a long time. Thanks for your answer.Interesting question, I hadn't heard of that before. I think I can dispel it, at least for Energizer CR123A cells (may be different for cheapo foreign cells)...
Just tried a couple of samples in the T10:It might be useful to know, at least at initial turn-on, what the tail current draw is for each of 123A cells for each of the tests.
Me wonders if some of the cells tested are the same exact manufacture, with pretty new labels on them, and different "batches" or freshnesses .
I thought you might be happy with the Titanium cell performance Matt. :laughing:How did I miss this before today???
Unknown... I'm pretty sure David said he could loose the supplier if the manufacturer was known.Which company makes 4Sevens batteries for them?
We sampled every major lithium manufacturer in the area and found most ofUnknown... I'm pretty sure David said he could loose the supplier if the manufacturer was known.
Seems a little odd, but I trust David's quality standards.
