goodfellas
- Joined
- Nov 15, 2011
- Messages
- 7
Are the 4Sevens batteries made in China or the US? The company itself is headquarted in the US, though, right?
Made in China, to 4Sevens' specifications. 4Sevens is a US-based company.Are the 4Sevens batteries made in China or the US? The company itself is headquarted in the US, though, right?
thank youThe made-in-the-USA Panasonics are excellent cells, equivalent to my Duracell Ultras and Surefires, in all my testing. In fact, Panasonic is probably the manufacturer for most of the USA cells.
AFAIK, the Duracell procells and ultras are identical.
If cheaper than Surefire/Duracell, sure - performance has always been equivalent in my runtime testing.so money aside, would it be better to get Pannys?
thank you very much!If cheaper than Surefire/Duracell, sure - performance has always been equivalent in my runtime testing.
I do have some more recent data - the performance of Titanium Innovation cells have improved since this original comparison was posted.I know this thread is old, but do you have any input on how the current Titanium Innovation CR123 cells are holding up? Just wondering if performance has changed before I buy some. I still have some Tenergy Propel, silver and purple label to burn up first. Thanks.
The different circuitries can be inferred by the different output runtime patterns. The light clearly differ in drive level (based on different outputs for equivalent emitters) and regulation pattern. To investigate the individual responses of different batteries to specific discharge currents would require the use of a hobby charger (which many here have done). The purpose of this thread is simply to demonstate how the batteries actually perform in the real world of individual lights.It would help if you would discuss what the different circuitries are and why it makes a difference. You mention draw rate?
New forum member here.
Found this very useful before stocking up on CR123a batteries. Pardon the "Newbie" question, but would these evaluations give you a somewhat accurate picture as to how these batteries would function in flashlights, weapons lights w/lasers and/or red dot scopes (mostly Surefire or EOtech products)?
Thanks!
Approximately, yes. Although it would be ideal to test batteries under standardized laboratory conditions where you could monitor actual voltage, I don't have the setup. My goal here was to show a couple of "real world" performance comparisons in a couple of flashlights. The results are hopefully comparable to other lights driven the comparable output levels.Pardon the "Newbie" question, but would these evaluations give you a somewhat accurate picture as to how these batteries would function in flashlights, weapons lights w/lasers and/or red dot scopes (mostly Surefire or EOtech products)?
I doubt they will get better - the problem is that Tenergy does not make very high quality cells (in either primary or rechargeable forms). Lights like the PD35 put a heavy drain on 2xRCR when run on Turbo. You will need to source higher quality RCR cells, or switch to 18650.Hey quick question I bought some tenergy rechargeables and when I get them in my fenix pd35 they don't run in turbo for very long maybe 5 seconds before the light shuts down. ... I think it's because they need to be broken in for a few more cycles.
