I've mod a convoy L5 host with a XHP50 led. It has a smooth reflector and yes there is still a 'dark spot' in the middle of the hot spot.
I'm not sure if that's because I couldn't focus the led properly or because it's just the quad die layout itself.
It seems that smooth reflectors should not be used with these emitters then.
Here is my 2 cents. After having used a handful of XHP-50 and 70s it does appear that the nearly forgotten doughnut has reared its ugly head a bit once again.
I first noticed it when I started mocking up the Copper P60 XHP-70. I use a OP reflector in this which has always delivered an exceptional beam with any of the modern emitters. However with this I did notice a slight dark spot in the middle.
I also made a 3x XHP-50 set up with a deep set of SMO reflectors and the result was significantly
worse.
For this set up I used some of the typical XML LED isolators to set the height. The ones with the little square cut in them that look sort of like a bow tie ( which focus XML perfectly).
Here is the beam profile with that setup.
I thought that was pretty nasty for a multi emitter set up. It was a fairly small doughnut but quite dark and noticeable I thought.
I had previously discovered with the OP reflector that changing the height was an effective fix for this. Here's the thing though. Often in times past to change focus moving the reflector OUT from the emitter was the thing to do. In the case of the P60s and the 3 XHP the opposite was true.
In order to remove the doughnut with a reflector made for an LED with XHP emitters you need to move the emitter DEEPER INTO THE REFLECTOR.
I spent some time machining off the base of the reflectors, in both cases this fixed the problem.
Here is a profile shot of the 3x XHP-50 light with the reflector shortened.
As you can see its still not MT-G2 quality, but in real life to my eyes it looks like about an 85% gain.
With the XHP-50s in my small single reflectors I found that simply
setting the reflector down flat around the emitter was a usable solution ( not perfect, but better, a little higher is better than this). That is not possible for the 70s but with the removal of between .020 and .040" from the base to lower the reflector I get a usable beam from any of the XHPs with any reflector I have tried ( which is only a few at this point).
Happy modding friends!
