Wow, glad everyone is OK. The damage is bad but it could have been a lot worse.
The light maybe 13 months old but the batteries could be a lot older than that.
Are these 2x CR123A have date stamp on them? Not sure if you could read them now after the fire.
You got to love how some vendor claim "matching" battery set without detailing how the matching was done. Do they actually measure the voltage and internal resistance or just
assume that the batteries are matched because they came from the same batch?
From my experience, the batteries IR does vary even when they are from the same batch. Even two perfectly matched cells will become unbalance from the heat generated by the light. You should check the batteries voltage once in a while. It is also a good ideal to mark and rotate the cells position. This need to be done often if you run your high-power light continuously. All this is hard to do when both cells are in a "matching" wrap
Base on another member's previous "
Scary problem with 4Sevens CR123", here is my theory on what happen:
The cell that sat closest to the head got empty first because of the heat. When the light keep on pulling current through the second cell, it reverse charged the empty cell. The empty cell heated up and vented some flamable gas directly into the warm/hot pill. When the light got really hot, the gas ignited. Now the second cell also got heat up very quickly and join the firery party.
I hope everyone stay safe and check the battery in your multi-cell light often. If the cell read a negative voltage, chuck it and run the other way
I really wish "
NewBie" would come out of retirement and do some more dissecting of all these new CR123A cells.
