Hello CampingMaster,
Years ago several tests were done showing the dangers of primary lithium cells. The basic problem was that lower quality cells often are not matched in capacity, and this can also happen if partially used cells are used with new cells. In order to generate the "rapid venting with flame" a few things need to be in place. You need heat, a cell that is being reversed charged, and enough time to get the chemical reaction going.
The basic safety aspects that came out of this testing were to use quality cells, to never mix partially used or different brands of cells with new cells in a multi cell light, to make sure the light is shut off and locked out, and to no worry about the last little bit of capacity in the cells. When the light starts to dim, replace the cells.
Following these procedures, the incidents of "exploding" flashlights has been greatly reduced. It is still not quite zero, but greatly reduced.
Tom
