There is a product out there called LED Seal, LEDSupply.com has it. its a spray on silicone sealant designed for LED's
Hero is a Chinese site, right? You can get Warm and Neutral Rebel ES's from Steve's LEDs for $2.99.
At 350mA sheet metal Aluminum is fine for XT-Es, XP-Gs and Rebel ES's. It's not thick enough for 700mA, and in that case you'll need an intermediate heat spreader, which is basically a thicker piece of aluminum.
Looks nice, but had a question....compared to regular light bulbs, how does the warm 3k cree leds compare as in tint?
The OP's lights are in the eaves protected from moisture, so there really is no need to coat the LEDs in his case. We are both running ~3500K Cree XR-Es and the color is warm and inviting.
Why xr-e over xm-l?
XP-Gs and XM-L's did not exist when the OP and I did our eave light projects. They run 12+ hours a day (through the evening hours) so they are getting their durability test daily. So far neither of us have had any issues.
I see...if you could do it over again, would you still go with xr-e? Or go with one of the other two? Also, do you have an idea how much it cost you every month to run those for 12 hours a day, all month long?
Depends on what, where, and how though. I still use XREs in certain places even though I have on hand XMLs... the high forward voltage is sometimes an advantage if the installation cost prevents the use of a constant current driver. The closer the V+ and Vf is, the LED can often police its own forward current if the duty cycle is short enough.
When the led's forward voltage is a tad higher than the input voltage, the LED acts as its own resistor. This is especially useful for accent lighting that was not designed to illuminate spaces but as a functional indicator.
I did a mod for a friend a couple weeks back, making LED drop-ins for his Toyota's courtsey lights. The Ebay bought six 5mm LED dropins were simply not bright enough.
DIY LED Dome/door light driver
Along the way I tested the setup using a Nichia ElaraMoon LED [Vf 3.5V @ 150ma] on a POL DC/DC converter that outputted 3.3V, and found the LED running nicely at ~90ma without a resistor and not increasing in current even as the LED package warms. In the end an XRE was used because at 350ma Vf = 3.3V. Even as the led heats up and the forward voltage decreases, the voltage margin is still around .1-.2V. In such situations, only a tiny bit of added resistance can underdrive the LED and let it stabilize the foward current on its own. For Eave lighting this is not cost effective, but for many indoor lighting siuations [photo lighting, under the counter lighting, night lights, etc.] it is.
