Arkayne
I was wondering, do you think the SF RED LEd ring has different resistor values than the white?
Indeed, I did replace the resistors with higher values when I swaped the OEM white LED's for 35K's from KevinL - details are shown in this post. I went from the 33ohms to 110ohms, which give me excellent results with the rechargable cells that I always use (MP700's from AW).AuroraLite said:Arkayne,
Issac's suggestion look quite promising, so it is definitely worth looking into. Also, IIRC, wquiles had also done the same mod here, and he might have switched his resistor value(for using with rechargables?)--might want to pm him for his opinion.
Better in what way?flashlight said:
Would the SMJ LEDS be better than the 40K ones?
My apologies. I did swap 35K's for MJLED's, but not in my A2, but in my POP-driven G2 LED Module . My A2 still has the 35K's and the larger (110ohm) resistors so even with the rechargable batteries I am doing fairly good (40mA max) so far - later on if one of them ever dies, I will put MJLED's to replace themAuroraLite said:That was the path that I took as well--swapping out the 35k for the MJ leds
