Have had a few good rides out on the road bike with this setup. It is outstanding.
So good I thought why not put one onto the MTB?
You need a bit more light than on the road and a wider beam.
I went for a quad R2 and medium MR11 optic from
cutter.
I thought about doing the same type of housing but
Nightlightning MR11 housings are good and reasonably cheap.
Brains from
Martin. Dynauto switches between high power at high speed and
boost at low speeds. I originally picked this up for the road bike but you don't really need the autoswitching function on the road. You always have time to switch manually.
Mount and Dynamo from the
LBS.
I went with the older shimano NX70 hub because they had one in stock and I got a good deal on it.
If I rode the MTB a lot or competitively I'd look at a newer model.
All I had to fabricate was the aluminium bracket between cateye mounts and lighthead,
and put a switch hole in the plastic cap that stops the steerer tube top. Also a small amount of glow in the dark inside the light head.
Mechanically it was very easy to put together.
Ill put a tie around the lighthead to catch it in case of bracket failure.
Thats the on/off button on top of the steerer tube.
Heres whats inside:
My steerer tube has a taper near the bottom so the board wont fall through... capacitors hang below it.
The dyno wires and LED wires run out the bottom (LED via connector).
And heres the business end:
Should put out around 650lm.
:rock::rock::rock::rock::rock:
