If you think about it Tim, what you really want is this thing for dimming. Makes you invisible from just a few meters away. The review says it's real good.
And your current switch can't be beat.
You could put the bulk in from the top then cablefrom th bottom of the stem no drilling neededIndeed, I felt like drilling some holes there. The parts that I have appear to be heavily over-designed, made to withstand jumps... But you're right, shouldn't take a risk.
... are you driving all four from the dyno circuit?
If you are what is the current through the LED's?
Thanks!Hello,
I'm not a regular visitor of bicycle forum, but I noticed the dyno-powered LED and immediately curious how one can capture the beamshot.
I really like your photo :twothumbs very nice night sky too; well done :thumbsup:
Hell znomit I never even noticed the switch in the forktube the first time I read this thread that is neat .
How have you preloaded the headset without the starnut and bolt
The circuit from pilom.com has two drive modes, 250 and 500mA, giving aprox 275 and 500lm. Normal riding on flat roads 275 didn't quite cut it, so the low mode only got used for low speed climbing and as a dip for oncoming traffic.
So, I figured with 2 more LEDs I'd run it on low almost all the time, less leg power required and have a huge boost for the downhills.
Out of curiousity, what's your typical speed riding on flats that you felt was outrunning the low setting? I remember reading before that you were concerned that too many LED's would end up soaking up wattage you would rather use for moving the bike.
Steve
I'm doing a 400miler in a few weeks and figure more light will help me keep awake through those nasty pre dawn hours and help to keep fatigue away.
Cool Is it a 600k brevet or something else? I didn't really start to appreciate bicycle lighting until I got stuck at the end of a double century without lighting for the last 15 miles or so.
Steve
znomit, Do you have a picture of the circuit you used for the dynamo?
I've read pilmo's site and being a newbie in reading electrical diagrams I'm confused by it.
Znomit, If I follow the pilom site and your picture correctly the resistors act as the bridge rectifier changing AC to DC? Am I following this correctly.
I'm toying with a circuit that allows me to use a home made dynamo (scavenged from a small electric motor from a CD player) I have the puts out approx 6V .5A. I wanted to try this out before I invest in a hub or bottle dynamo.
The circuit would run a Luxeon K2 LED. At .5a it won't be super bright (100lm) but it will allow me to prove things out enough to make up my mind to switch one of my lights over to dyno-power from battery pack.
