xevious
There's one thing about heat you can feel versus the actual temperature inside the light. What concerns me is that if there's insufficient heat dissipation, then the electronics will be stressed much more, shortening their lifespan. What would really help to know is what the average temperature inside is when running on high for long periods...Any actual tests I've seen with these lights (EA4 and EA8) show that they have no problem with heat dissipation. My EA8W gets plenty warm after running on turbo for a few minutes. I can appreciate that they chose not to add any unnecessary weight, the light is heavy enough as it is (and well-balanced).
Either the innards are being forced to absorb more heat than they should, or the emitter/driver combination is engineered in such a way that heat generation has been significantly reduced. But if the latter was the case, wouldn't NiteCore be boasting about this rather than slathering on so much Loctite to try keeping casual people from examining the inner construction? (I don't buy it was done to foil the competition from examining the internal design, because any competent professional can take apart a light no matter how much Loctite you use).
