bcwang
Power Me Up,
You had good answers to all my points so I'm not going to bother quoting them. I'm still wondering about the huge inconsistency in the XX cells, even if the slightly higher capacity is the reason they don't outlast the turnigy cells in number of cycles. I have some questions that may jog more conversation.
- You are terminating the discharge at 0.9v but is this as measured under load or during a pause? If during a pause, the cells may be over discharged.
- This version of the charger isn't able to do constant discharge current I thought, isn't it only able to drain through a resistor? Or am I mistaken and you can control the current very well? If the current is just based on cell voltage, if the XX cells hold higher voltage under discharge than the Tunirgy, they are also discharging at a higher rate and thus under harder conditions.
- To answer one of your questions, the voltage profile of eneloops seems to be higher than some other nimh cells in the regard that they are at a higher voltage. In the MH-C9000 charger for instance, some brands of cell can terminate on -delta V, while Eneloops always end on peak V limit of 1.47v. Maybe most Nimh behave like eneloop and it's the few outliers that are lower voltage. But it is known that the C9000 never terminates on -delta V for eneloop.
- The graphs you generated of the voltage and temp during charging, are those voltages measured under charge load or during pauses between charge pulses? The reason I ask is the C9000 measures during a pause and ends charge termination at 1.47v. Your charts show voltages up around 1.52v. If they were measured the same way, the inflection point termination is definitely ending much further beyond where the C9000 ends it's charge. I'm not saying it's over charging since the c9000 is undercharging eneloops and has to depend on a top-off 100ma 2 hour charge to fill up the rest of the cell. But I wonder if handling the top off gently like that leads to prolonged cell life.
-The cell temperature in that graph, where is the measurement point? If it's a thermistor only contacted by conduction through a charge terminal, the actual cell temp may be much hotter. I'm just trying to get a gauge of how much earlier your inflection point algorithm is ending the charge compared to when the cell temps start to really rise.
-Does the charger/discharger contribute any heat that may be influencing cell temperature?
- With this analyzer you have - I think a potentially valuable test would be to compare life cycles if you only drain to 1v rather than 0.9v under load and see if it improves cell life greatly. You could also have variations which may showcase how nimh life can be greatly improved (or not) by avoiding full charge and full discharge:
0.9v discharge cutoff - full charge
1.0v discharge cutoff - full charge
0.9v discharge cutoff - 90% charge (maybe with peak voltage termination to hopefully hit before any of the other termination methods)
1.0v discharge cutoff - 90% charge
-An unrelated topic but for your firmware - Maybe a mode that can end charge earlier (maybe by customizable peak voltage) with hopes that it can increase cycle life. Kind of like li-ion where partial charge and discharge net far better life. I'm not sure with Nimh chemistry if the full charge chemical process helps keep the chemicals more balanced for longer life. But if there is no benefit to a full charge and only risk with extra heat and wear, a charge less than full may be a great contributor to battery life and I can believe many people don't need the full capacity of the battery and would prefer longer cycle life. Test evidence that this helps batteries last would really seal the deal for the need for this kind of feature in a charger.
I'm actually a backer of the lcd version of the charger so I'm really looking forward to using it!
