Re: Trouble from 1.8 volts? - even in 2AA use?
How about this idea if you need Lithiums in the glove box for their long shelf life?
Suck the Lithium down to 1.5 volts and then use it. I had three Lithiums in a radio and noticed that one had 1.5 volts left when two of the three had pretty much died and the radio wouldn't play on FM. I should be able to use that cell without danger.
Some Petzl LED lights warn AGAINST using lithium primaries. It causes these lights to over heat. It may not fail right away, but LED life will be shortened.
