Patriot, were you using the 900 mah Tenergy's or the 750's?
Being that the WA ballast output is dependent on input voltage, does the 4 primaries setup (14.8 Nominal Volts) in the pack yield a brighter light (initially) than the 4-pack of 3.0's (12 Volts) or do the primaries immediately sag to a voltage below the 4-pack of 3.0 Volt cells?
Mac or someone, what is the maximum input voltage the ballast and/or lamp will handle?
Mac kinda already covered everything. I'm using these:
http://batteryjunction.com/rc390reliba.html and yes, they're "900mah." The rechargeables yield brighter light because of the additional voltage. There is also less fade at the bottom edge of the corona with the 4 x 3.0V RCRs. After about 25 minutes though there is virtually no difference in the appearance of the beam vs. primaries. I like the convenience of the 3.0V RCRs though and I don't feel like I'm hammering the ballast as with 4 x 3.7V RCRs, although as Mac stated it sounds like at least one person is getting away with it. I wasn't quite that brave.
