Eznite JX 101 CR (10watt mini-HID) review UPDATED: More pictures !!
Ra
The Netherlands
Hi guyzz,
I hope this will be worth the waiting.. I needed some time to make this review as complete as possible.
A lot has been written about it, the introduction thread already has 22,000+ views.. So.. its about time to test this new mini-HID, and see if it's just the way it looks, or that we can expect performance as well. (would be nice, wouldn't it??)
Reading the introduction thread, I asked myself.. Could this be the first production-torch with the same philosophy as I build my mini-HID monster with?
I don't know what was discussed during the 'design-meetings' at JIL Lite: Did they include the sideways lamp-collimation only to allow us to get a nice round beampattern? Or did they think like I did a few years ago: Concentrate the focus on one of the hotspots within the arc and you will have a significant increase of candlepower-output!
No matter what they thought, lets see if they did a good job:
For those among you that don't want to read this entire review: Reading the "conclusion" section at the end of the review will give you a pretty good impression of this light..
So, lets get started…
About a week ago, I received the unit with serial no. 0008.
Carefully packed in a nice box, together with some warnings and an artistic, quick manual (very quick..)
The light itself definitely doesn't look or feel cheap. One remark I want to make is: WHERE IS THE LANYARD???
A light this small and fragile needs a lanyard included, because it will definitely be damaged if dropped (accidentally or not..) Especially the edge of the head-section is very fragile!
In Holland, we have a saying: If you drop a piece of bread with peanut-butter, it always lands with the peanut-butter downwards! So, use a lanyard, or connect the light to a chain around your neck. But don't give this beauty any opportunity to fall!
So this is a baby you must keep your eyes on, but the way it looks, that shouldn't be a problem. (tho that is a matter of taste..)
Shot with DSC-R1 at 2007-06-24
My mini-HID at the left..
So, what's inside the little monster? A Welch Allyn 10 watt ballast and bulb, four CR123a cells (non regargable) in a simply removable battery-holder. A very high quality electro-formed parabolic mirror, and a 'clicky' switch that feels firm and reliable.
The manufacturer claims a runtime of up to one hour.
A (regulated?) regargable battery option will be aviable in the nearby future.
So, how to proceed with this review? Well, let me think…
- Lots of beamshots, extensive runtime tests during which headtemperature, relative light-output and battery-voltage is measured.
- Graphs to easily understand measurement-data
- Calibrated candlepower measurement
- Did I mention lots of beamshots!?
- Oh.. And ofcource submerge in water-tests, 'drop on concrete floor' tests and 'smash against concrete wall' tests. After that, I think Warren will start his 'kill Ra' tests!! So lets forget the destructive tests and do something constructive..
Look and feel:
With the smooth and high quality anodized aluminum body, this definitely is a torch you can enjoy for years and years, if taken care of that is.
Like I said earlier, its fragile, especially the head-section: A minor hit with the edge of the head against a wooden table can already cause deformations!
The 'clicky' at the back seems to be of high quality: It should be because of the nasty current-peak it will feel at startup!
If you ask me: It's a torch with a high 'flashaholic' factor. Tho I've read remarks like "looks like a zoom-lens" (but some like zoom-lenses, so what's the problem..?)
I don't think the Eznite is waterproof, it's waterresistant at the most. So it probably will survive a shower, but not a dive!
Overall performance:
Switch it on and you will definitely be confronted with one aspect of the nature of HID: It needs about 15 seconds to get to full output.. Strobing is out of the question: If you want to enjoy the performance for years to come, you should not use this torch for shorter periods than 5 minutes!
Important remark: If you 'tab' the 'clicky' without clicking it off, the lamp shuts off with the switch still in the 'on' position! Unlike with halogens, the lamp will not come to life unless you switch it off an turn it back on after 3 seconds!
As far as I know, this does not damage the torch or drain your batteries.
Beamfocus:
Here comes the fun part: Three screws at the side of the torch to collimate the bulb along the x- and y-axis! (Together with turning of the head for z-axis beamfocus).
If you do this right, you can obtain a very smooth beampattern without much artifacts!
But even more: You can focus the bulb to concentrate on the hotspot within the arc, near the anode of the bulb:
Shot at 2007-07-03
This hotspot has much higher surface-brightness (needed for throw!). The result will be a beampattern with a nice flood and a very intense center. The cp-value at the center can go up to 180,000cp or even higher!
Remember: This can only be done with a high quality electroformed parabolic mirror and a bulb with the protective envelope removed!
Some asked me to a side-by-side comparison with my 10 watt Mini-HID monster. As I don't have anything else to compare it with, on some fields, I'm going to do that. But during this comparison, you must remember one thing: The Eznite is a production-torch! My mini-HID is not.
With my mini, I have done everything possible to squeeze every torchlumen and candlepower out of it! That is a very expensive process, not doable with a production-torch ( ohh, it's doable, but it will have a prizetag at lleast three times that of the Eznite!)
So don't be to harsh on the Eznite when it doesn't reach the specs of my Mini-HID
My mini is somewhat bigger: It runs on 18650 type cells and has a slightly larger reflector-diameter. I'm shure the Eznite will grow in length one inch or even more with the regargable 18650-cell option.
Lets have a graph:
I did a (nearly ..) full runtime test, monitoring the head-temperature, voltage, and relative torchlumens output. This test is done in two sessions, 10 minutes apart, to keep the head-temp below 60 degrees centigrade (140 F) I'm shure it will survive higher temperatures, but I don't want to push the envelope with this pass-around unit..) First session is 30 minutes long, you will see a no-data area between minute 30 and 31: That is the 10 minute cool down-period.
Shot at 2007-07-03
As you can see, the Eznite meets the claimed one hour runtime, but during that, output decreases to about 40%.
For a torch that needs to be practical, this runtime is quite short. Especially with torches this small and portable, I want to see runtimes of at least 1.5, preferably 2 hours!
This is the prize you must pay if you want a small torch: The electronics and bulb need their space, decreasing the size of the torch drastically deceases room for batteries!
The ballast clearly is not regulated, and with the increasing internal resistance of the cells over time, the voltage and output drops.
At max 9.93 volts from the four CR123a cells, the Eznite is a little bit underdriven. So it probably won't reach the 500 bulblumens-mark with this battery-setup, more like 450 bulblumens. But who will notice??
After just a few minutes over one hour, it will start to flicker. That is the moment to turn it off: I'm not shure, but somewhere I heard that these ballasts and bulbs don't like empty batteries, and damage or shorter bulb-lifespan can be the result of that!
Then there is the head-temperature: Though the electronics can survive temperatures up to 100 degrees Centigrade (212 F). The Eznite does not have the 'massive-heatsink-design' like my mini has.
Small torches don't have the outside surface needed for good heat-dissipation.
So the head of the Eznite gets hot. If you ask me, a little bit too hot: 60 degrees Centigrade at 19.5 centigrade ambient temperature is one thing.. I'm not shure what happens when you continuously use this torch at 40 degrees ambient temperature, but I would probably not be happy with the way it heats up in such a situation!
The positive part of this: Warm hands when walking in the cold with the Eznite.
When I saw the first pictures of the Eznite, I saw a Rhodiun-coated reflector (slight brownish, lower reflection-look), however, the reflector of unit 0008 seems to be aluminum-coated. The difference: Aluminum reflects up to 90% of the light, Rhodium more like 76% ! But Rhodium is more durable and can withstand high levels of UV-radiation.
With my Mini-HID, I used a (much more expensive!) dichroic-multilayer coated reflector: 98% reflection. The picture below shows the difference in reflection between the two reflectors.
Shot at 2007-07-03
So, how does the beampattern look like? Time for some beamshots:
For practical use, I would recommend a limited focus-range: Between focusing at the hotspot near the cathode, and focusing on the hotspot near the anode.
Go beyond those two limits and you will end up with a dark hole in the center of the beampattern: (donutlike beamshape).
Within the range I mentioned above, two focus-settings are worth to be mentioned:
-Focusing at the middle-section of the arc:
Shot at 2007-08-18
This produces the most narrow beampattern possible, with decent average cp-values and no distinct hotspot (-s).
-Focusing at the hotspot within the arc near the anode:
Shot at 2007-07-03
This produces a much wider beam pattern with a very intense hotspot. With this high-candlepower hotspot, you can illuminate objects more then 500 yards away! (depending on the reflectivity of the objects ofcource..) And still enjoy decent side spill, though this side spill is less powerful then at middle-focus.
So, how does this look like in the field (or forest..):
Middle focus:
Shot with DSC-R1 at 2007-07-03
Anode hotspot-focus:
In this picture you can clearly see the trees at 190 yards being lit by the hotspot.
In a head-to-head beamshot comparison between the Eznite (with fresh cells) and my Mini-HID, my HID produces about 50% more torchlumens, and about 25% more CP's:
Shot at 2007-06-24
But like I said earlier: It's not fair to compare a "one-year-painstaking-effort supertorch" with a "production-supertorch"!!
So, what about the emitted spectrum.. Well, lets have a look:
This is the spectrum emitted by the Eznite:
Shot at 2007-07-03
And this is the spectrum, emitted by the bulb only:
Shot at 2007-07-03
So, there is no UV-radiation to worry about.
I also checked the transmission of the front-window; nicely blocking UV-C , UV-B and most part of UV-A, but as you can see, bulb only doesn't emit much light in those regions anyway. I measured down to 195 nm and got almost flat zero! So I omitted that part.
And for those who want to know: The emitted spectrum of my mini-HID:
Shot at 2007-07-03
As you can see: It belongs to the same family!
Conclusion:
With the ongoing revolution in the LED-world, the question is if a HID like this will survive for long. Put a few Cree's or Seoul's together and you can easily get the same lumens-output or more, with the same efficiency or better, with instant-on capability
The key-word is surface brightness: No doubt LED's will surpass the best halogens on surface brightness very soon, but it will be years before led-lights with the same dimensions as the Eznite will reach the same throw as this little monster!
A few :thinking::thinking: tho:
The bulb seems hard to change, pulling by grabbing the bulb seems the only option, but definitely will break the envelope!
Then there is the heat production: The three screws at the side for bulb-collimation move the ballast in the x- and y-direction, this means that there is a airspace between the ballast and the body. Air is not much of a heat conductor! So when the temperature of the reflector-head hits 60 degrees centigrade, the ballast-temperature will be much higher!
I also have minor doubt's regarding the clicky: Like I said earlier, unlike with halogens, any power-interruption, no matter how short, causes an immediate shut-off.
It needs a reset of 3 seconds to recover!
However, during the tests I did, the Eznite's performance was great!
I have never seen a production-torch this small with cp-rating this high, and I'm shure you will agree!
If you know how, you can obtain very nice beam patterns without nasty artifacts, by collimating the bulb sideways.
The runtime chart clearly shows a drop in performance during the (quite short?) one hour runtime. The upcoming regulated (?) 18650-option will change that, but will cause an increase in length of the Eznite as well.
My mini-HID performs better on both cp- and lumens-output, but comparing the two is not fair: the Eznite is a production-torch, my mini-HID is not! A production-torch needs to have a reasonable prizetag. With that in mind, I can only say: GOOD JOB GUYZZZ! :bow::bow::bow:
If I have left out, or forgot something, please lit me know..
UPDATE:
Quad-cell CR123a battery holder:
Shot with DSC-R1 at 2007-07-22
One of the three bulb-collimation screws:
World smallest, fully functional HID-bulb.. (Yep its even smaller then a common household match !)
Best regards,
Ra.
starfiretoo
KAUAI
Re: Eznite JX 101 CR (10watt mini-HID) review
:thanks: Ra
Can't wait to see it in person in the group passaround...
wintermute
Sounds excellent Ra. I also don't think I have commended you in your thread about your MiniHID Monster, but that thing is amazing. I can only hope to be able to build something like that in the future.
I really hope I got in on this EZnite pass around, but I have no clue since the OP hasn't updated the list of who's getting it - but I am hopeful.
Thanks for the excellent review - it really helps that you have something to compare it against...something that many of us won't.
:twothumbs
karlthev
Pennsylvania
Great review!! Thanks so much for the time and effort!:thumbsup:
Karl
LuxLuthor
MS
WOW, what an incredible review you did here, Ra. You covered everything from soup to nuts and gave it a very fair and balanced evaluation. It will be interesting to see what those who have the Elephant 10W HIDs will say as another comparison. Thanks for all the time you took doing this so professionally!!! :thumbsup:
chesterqw
singapore,jurong
/me uses flame thrower to lit Ra
you forgot the flashlight porn... head pic isn't enough...
we need full body :p
easilyled
Middlesex, UK
Thanks a lot for the review and confirming the safe UV emissions :)
It sounds like Jil/Eznite smashed the cricket ball high up into the pavilion
(where the selectors were sipping their finest grade Earl Grey tea) with this
little gem. ;)
jefft
Cupertino, CA
Ra, absolutely superb review!! They don't get any better than this.
jtice
West Virginia
Fantastic review Ra :thumbsup:
As you said, with a production light, its always about a compromise to balance out the features and output, and still fall in a decent price bracket.
The small size, and high focus ajustability are the Eznites key features.
It certainly is small, as small as some of the smallest MiniHID Mag Mods I have seen,
yet it adds the awesome focus adjustment. Which has plagued many lights.
For me personally though,
I still like sticking to leds and incan mods for the 500 or less lumens range.
I maintain the instant strike ability, which is very important to me.
The lack of regulation is a turnoff to me as well. Though this is the case with many non LED lights.
A couple questions if you dont mind,
You said you think its somewhat water resistant,
do you not think the 3 focus adjusting screws are a weak spot even for rain?
Does the focusing system seem to be rigged?
Does it stay in focus if you smacj the light against your hand a few times?
I am looking forward to checking out the light in the passaround.
and will compare it to my 10W MiniHID Mag.
Again, excellent work on the review, its greatly appreciated.
~John
Kiessling
Old World
Good review !!! Thanx !!
I guess though that the light will be a victim of the new LEDs, at least what I am concerned.
bernie
Ra
The Netherlands
~John
Thanks John,
I don't think the 3 screws are a weak spot, they fit exactly into the holes. And you can apply some grease to keep the water out!
The sideways focus-system is very stable, even when you untighten the screws it's hard to force a focus-change by smashing the light against your hand! The only doubt I have is, can the ballast be damaged by tightening the screws too much??
So best is to untighten all screws and focus with tightening and untightening the screws one by one, and when focus is ok you can gently tighten all screws. If you tighten one screw, the other two must be untightened first!
Regards,
Ra.
Patriot
Arizona
I always enjoy your reviews Ra. Thanks for all the work that you put into it. I think I'll be more interested in the 18650 even if it's a bit longer as run-time to me is more important.
ms1496
NE Ohio
Excellent, Looks like another well made must have! Thanks for the review.:thumbsup:
justlux
UK
Hi Guys,
I have bought the rechargable 10W Eznite and wondered if it was waterproof to IPX-8 standard?
nein166
New York
Hi Guys,
You should contact Jillite as to the waterproofness,
But it is not a Dive light. IPX8 is over a meter for hours.
And if water does get in it can't interfere with operation, so it doesn't mean waterproof.
I wouldn't take mine more than a foot underwater.
It isn't double o-ringed on the front or battery pack and I don't know if the switch is sealed to ingress of water.
