Re: interest thread ... High-Current 6AA>2D adapters
This is a working prototype, it's definitely rough around the edges, but it does work as intended.
More kinks to work out yet, but it's getting closer.. One thing interesting about this design, is that, you can really clamp down on the cells, the threads on the screws that hold the end-plates on do not strip out of the plastic as easily as I thought they might (good thing)... but it means that with the torque you can apply to the socket drive screw, you can actually damage the ends of your cells if you aren't careful. I will be switching the design to use a flat headed screw for contact surfaces to help spread out the load more (used button top for the prototype)...
I am currently using this prototype in a 2D (pictured) with a mag 6 cell xenon with no issues... During the assembly of the pack, I accidentally installed an end-cap in the wrong orientation and had the cells shorted out in the carrier for about 20-30 seconds before I noticed some major heat.. The plastic did not melt, the contacts and everything remained intact with no perceivable damage, suggesting that the pack will be able to handle heated situations.
I need to slim down the design, overall, I'm too big in every possible direction, It's way too snug in the mag body, and the length is over by at least 5mm at this time (but the mag does screw down all the way even with the extra length, end up with a tighter spring, which may be a good thing for those using it in a 2D mag, but wouldn't be stackable in a 4D with this excess length.)
[edit in 10-25] I put the pack on my RC pack charger and cranked it up to 4 amps, no problem charging at this rate, contacts only rose in temp with the cells themselves, pack charged without a hitch.
