Hello all
I'm going to try a different design before I start any sort of production, I'm having a really hard time on the drill press with these long drills, because the material isn't being removed equally on the bit (outer edge hangs over the edge of the rod stock)... so as the bit drives down, it isn't holding straight, play in the bits flexibility combined with whatever play is in the bearings is allowing the bit to run out of true as it works it's way down the cut, so the cell spacing top and bottom are not uniform. My drill press is reasonably large in size, so I'm amazed I'm having this much trouble.... but I am looking at a new design that would be less dependent on the press being so rigid, but it won't have the same "cell protecting" qualities as the original prototype.
Parallel or series packs really isn't a problem, I can make some quick changes to the design for either setup. I'll be starting with series wired packs, but I'll be sure to get some parallel packs on the table at some point. Parallel packs are actually a lot easier to make the end-caps for, so it's not that big of a deal.
