varuscelli
I really need 2.5 to 3hrs of use. Don't think I want the Wilma X. It is overkill, although it is kinda nice to fry the shrimp's eyes so they won't see the dip net coming:laughing:. The Fenix will still have it's use. It's beam it's plenty wide at 20ft away, great for dipping up blue crabs from a 15ft high bridge.
For a slightly different twist on what you need, have you considered the option of using the Fenix Headband (the one that's sold separately, not the HP11 or HP20)?
With the Fenix Headband, you can purchase the flashlight of choice and use either one or two flashlights to give you whatever beam pattern you'd like, and probably have more flexibility in choosing the light that might work best for you.
I recently purchased a Fenix Headband and use it in various configurations. What I like to do is use it with a flashlight that will accommodate AA rechargeable batteries so that if I run low on power all I have to do is insert new batteries, which are easy enough to carry along.
I even set up one of these for a friend to use for frog gigging -- and that concept is very similar to what you're doing.
With the cost of the Fenix Headband being only about $22 USD, I'd say that coupling it with the right flashlight (or two flashlights) is a workable option compared to a headlamp, especially given your specific needs. That is, in the hunt to find just the right headlamp, you might more easily find a better combination of Fenix Headband and a couple of flashlights (perhaps even two flashlights with different beam patterns to meet different needs you might have on the same evening).
And if you're considering moving up to a much more expensive headlamp option than the HP11, there's even more reason to consider the Fenix Headband plus appropriate flashlights.
OK...I just wanted to give you something else to think about...
Below is the Fenix Headband with a Fenix L2D and a NiteCore D10 (a couple of my old but often used lights). As a "for instance" on the use of this, I can use the L2D for distance and ramp the NiteCore down to a minimal amount of light (and angle it downward) to see what's at my feet or in my hands. With this headband, you can tilt each light to whatever angle you want. There are lots of variations on the possibilities.
The drawback to the setup as shown is weight, but you could easily choose flashlights that use a single rechargeable AA or a single rechargeable RCR123A batteries to cut down on weight.
