kaichu dento
That's the one I'm looking for too.i wouldn't mind getting one with a 'fenix orange' body
As it is now the LD20 is a bit too throwy, but usable. I want some spill for cycling. The older L2D had a bit more spill relative to the LD20 and even though the LD20 is theoretically very slightly brighter, it's smaller hotspot and less spill result in me preferring the L2D.Keep in mind that the LD40 has a more focused beam. In terms of throw the high mode should be close to the LD20's turbo.
I don't know. I do know that the L2D has a better spill vs. LD20 and the LD20 has a tighter hotspot and better throw.noisebeam,
Just wonder here: does really better throw result in less spill? :thinking:
And what do you mean with "less"?
Regards, Patric
Yeah, that describes it. I only bar mount and will never head mount so I prefer a wider beam. I actually returned an LD20 for an L2D because of this.I meant that the L2D has a wider beam both overall and also concerning hotspot size, which is often considered better for a bar mounted bike light.
The LD20 however, is driven harder on Turbo, but lower on the low/med/high modes, so there is a more noticable difference. Also it has a tighter hotspot and spill profile, so that both are brighter and so more suited to throw, perfect for a head mounted bike light.
I wonder how yellowish the "neutral" white will actually look. Like a regular 4300k car headlight bulb? That's a little lame.
As a lover of AA cells I am keeping my eye very closely on the LD40.
Run times on max look great.
There seriously needs to be more lights that run on 4 AA cells. 4 AA cells are a good number to use.. nice runtimes and not too heavy for carrying a backup set.
Care to share what modes the damn thing actually has?Got my LD25! Initial impressions are quite good in regards to build quality and functionality. The plastic grip has a nice texture to it for improved hold. The head turns with just the right amount of ease for mode changes; no extra lube required.
Because Fenix went with a smooth reflector, the hotspot has a slightly brighter ring around it, and then a softer corona beyond it before moving into the spill. Outside, where the light is intended for use, this is not noticeable unless you are aiming it against a flat surface or are looking for it. Personally, I wouldn't mind an OP reflector, but that's me. Doesn't seem too easy to get at the reflector or lens.
Tint is nice, not too warm, but a good neutral. IIRC the light pulls around 1.4A on high, so not too much over an hour's runtime per eneloop charge, maybe an 70-75 mins, I'd think.
The plastic grip is nice; I really like it alot more than I thought I would. From farther than a few inches away, the light looks all aluminum, which is also nice IMHO. I can see that holding it for awhile in chilly weather would definitely be an improvement vs all aluminum.
LD40 looks good. Just not sure how practical in use the second dimmer button will work out. What happens if both buttons are accidentally depressed?
