georges80
Okay, besides the Zetex ZXSC300, which alot of folks seem to use here, which ones are they using that run in the "1.5-3MHz range"?
-> Linear Tech. Even the venerable LT1618 runs at 1.4MHz. Linear Tech has faster parts as well, with synchronous rectification as well.
Higher switching frequencies also equates to higher loses on the MOSFET gates, because you need to drive that gate capacitance (and other associated capacitances) around. The faster you drive it, the more energy you waste there.
-> Yep - the tradeoff of the high freq benefit of being able to use tiny inductors & caps is the time the FETs spend in their linear state.
Power loss due to gate charge = Switching frequency * Total Gate Charge (Qgd_total) * Maximum Gate Voltage
..."6.8uH (or a bit lower as you say) and 0.0023ohms - is that a misprint or a large inductor with THICK wires?"...
No misprint, wound with litz wire, many strands of fine magnet wire (the strands are probably about 42 guage, looking at it), designed to reduce eddy current losses.
-> I looked at your inductor - it is large - hence has room for all that wire.
Used a 4 wire kelvin bridge (basically have to at those low values).
Yeah, that Panasonic part is as big as a sandwich, but it is no problem for D cell mag-lite mod.
-> True - it all depends on the host torch. But then with D cells the ultimate in efficiency (other than feeling good /ubbthreads/images/graemlins/wink.gif) isn't that critical. Also in that form factor running multiple cells and down converting becomes feasible.
A designing a switching power supply is quite a dance to get the optimium efficiency in the desired form factor at the power levels needed, then add in the input voltage range, etc. and it can become quite an endeavor...
-> I totally agree, lots of tradeoffs, not least of which is cost/size/performance. Like I wrote before, the TI part looks interesting, if you try it at higher drive levels in the 750mA-1A range it would be interesting to see the efficiency numbers (just to verify TI's claim of 90+%). Also, getting an opamp feedback path from a sense resistor will be interesting - mainly to see if the TI switcher's FB control loop can run stable with an active component in that path.
Please keep us informed with your ongoing evaluation of the TI part /ubbthreads/images/graemlins/thumbsup.gif
george.
george.
