While I'll agree that rechargeable cells make absolutely no sense in remotes. clocks, and test meters,
My first thought is that it would have to be very expensive equipment considering the ongoing added expense of lithiums. How do you justify it with a clock?IF a lithium cell would leak, it won't damage the metal contacts and eat away the springs. This long lasting damage free use may justify the expense of lithiums. Of course YMMV.
I used a fresh Eneloop (AA) in my wall clock and it lasted only a few weeks before the clock became slow.
All this just proves that alkalines and L91s are here to stay with us. The eneloop is great for most applications but sometimes it really fails.
Fair enough, ltiu, but that's not "just" a clock - if you don't have a backup your job could depend on it.
I use 3 AA eneloops in my carbon monoxide monitor for the same reason.
TorchBoy: Fair enough, ltiu, but that's not "just" a clock - if you don't have a backup your job could depend on it.
And when one's life depends on something like a smoke detector or CO detector, I would not want to use a rechargeable NiMH or NiCd. When using alkalines or lithium, the "low voltage" warning chirp the detector emits lasts for several days, which ensures you hear the warning in order to heed it. However, when a rechargeable's voltage drops off, it does so quickly and precipitously. The detector need only lose one cell while one is away for the day or the weekend, and one will never know it went bye-bye. I believe detector manufacturers explicitly state not to use rechargebles for this very reason.
Your terminology implies that the Eneloop didn't perform within its design parameters etc, which is highly unlikely.
It's also much more likely that the real failures are going to be those manufacturers who persist in marketing devices that will only work with lithiums and alkalines, and are deficient in incorporating rechargeables in their design.
So pls tell me why do Eneloops feed torches better than Alkalines do or shall I say why does a torch perform better on Eneloops than Alkalines.
