Can you dedome the led ?
I personally would not want to do it, but I'm sure we can find a source to buy one de-domed if you want...
Magnificent build as always Jay.
i was thinking of doing the same mods to a friend of mines mag. however its a 6D mag..so if im correct id need a driver that will handle 9v input with standard Duracell cells or 22.2v with Li-ion batteries. im new to 32650 cells and was under the impression that of the shelf non rechargeable D cells had a higher mah rating than the 6000mah feilongs?? not sure with which ones to go with on the build.. rechargeable or off the shelf, and also which driver would do the job?
Jayrob
Would you consider selling another Aluminum heatsink for the 20mm LED star?
Thanks
Wow this is one heck of a light
I just ran out of battery, been using this for walks and all sorts of minor flashlight needs.
It held a charge for over 6 months of lot of low volume use.
Amazing
I was bad it went red months ago but still kept going I kind of wanted to see how long it would go
It went longer on red then Blue. Just charged up I'm back will not let it run down again.
Still an awesome light
I will post a picture comparing my other mag light custom that you sent me the lens for
I will show you how awesome your light is
Thanks again
How would you compare this to the MT-G2? Is this as floody? Or is this the MT-G2 on steroids?
Thanks
Steve
Could you do this build on a gen 3 mag lite? Curious because it has more room and might allow a deeper reflector...
No I didn't think it was as good because of the smaller head, less room inside actually...
Ok cool . I need a xhp 70 one then. I still the MT G2 light you made me as well.
Good day everyone, I'm just a new guy in CPF. Your XHP70 mods is one of the best mag mods I'd ever seen. Photo shown above seem very bright widely. Have u consider to dedome the led to increase beam throw? Will it work?
