jayrob - I'm interested in one of your 4000Lumin XHP70 Mag Mod with Voltage Monitor lights. Not sure about some options so I'll ask you about them here in GREEN. I'll list my choices in REDwhen I am sure which options I want.
Build Details:
BLACK * 2D Mag (let me know your color choice)
YES * XHP70 6V N4 5000K emitter set on custom heatsink as shown
* Copper or Aluminum heatsink option. What is the functional performance difference between Aluminum or Copper heatsink?
YES * 5 Amp, 3 mode driver - L,M,H w/memory (see current readings below)
MOP * Aluminum reflector (specify smooth or MOP)
* Borofloat high temp glass lens (or UCL glass lens) Functional difference?
yes * Fine focus adjustment
yes * Voltage monitor option
* 2 - 32650 Li-Ion Batteries What is the functional/performance difference between protected and non protected batteries?
I have a custom programmable LI-Ion Charger. Anything I missed?
These emitters are 6 Volt emitters. At 5 Amps, that's 30 Watts of heat. So on medium or low you can leave it on. But on high you must watch your run time. The copper sink will be better on high but still you will want to watch your run time on high mode. Like maybe 5 or 10 minutes. (although I'm sure it can be longer but I like to be conservative)
Borofloat is for high temp but honestly the UCL is fine and has slightly better transmission.
Non-protected cells are better in my opinion but if you are not getting the voltage monitor option, then protected may be better. It depends on how 'battery conscience' you are. If you are one who is always watching your battery voltage then you don't need the voltage monitor or the protected cells.
I am very battery conscience, but I still like the voltage monitor, but I like the non-protected cells...
About your charger. As long as it will fit the 32650 size...
Send me a PM for ordering!
