GLOCK18
Re: FS *C-Flex* C Li-ion battery Tubes, Extenders & Adaptors for E & C Series, TnC &
I'm in for the one with fins.
Although we have been working on other projects, the C-Flex is still on the table for potential additional parts to be built. An example is the M@G reflector compatible head. Below are three v1 C-Flex head drawings using the standard C-Flex 1x C Li-ion tube. The thinking behind this design is to allow users to take off the shelf M@G custom reflectors, aspheric, multi-LED as well as hotwires setups and use them with these C-Flex heads and tubes. There is no adaptor needed on these heads as they mate directly to the C-Flex tubes. These heads will not work on M@G tubes. If you have interest in seeing these built then please post!
No, you need the "TnC C-Flex C Series Adapter". The adapter you list above is for TnC's SF-series heads.So, I've got a nice AW C cell that needs a new home, since it's partner decided to die in my ROP. I'm definitely thinking of a C-Flex for incredible runtime with a nice Malkoff dropin.
Since there aren't incredibly verbose descriptions on the website I just want to check on what I need to make a functional light. SO I'd need...
1) C-FLex Batter tube w/ clickie
2) "TnC C-Flex SF Series Adaptor" (I'm presuming this is compatable with C series, as the other SF one specifically says E-Series.)
Slightly confusing naming imho.
But with these, my AW C LiIon, a C Series compatable head, and an M30 dropin I should have everything needed for a whole working light correct?
Would it be possible to make some type of adapter to use 18650 batteries for these C flex tubes, since the Aw C batteries are no longer available. I would be in for 3.
