Ouch! These clips are actually pure titanium, not an alloy, so the material is comparatively soft. On the plus side it has excellent fatigue strength and should bend back to it's original condition without much fuss. If you'd like some pointers on how to get it nice a flat let me know. Basically a hammer and a couple blocks of wood should do the trick. You might get away with just using a pair of pliers if you are careful. Of course you'll have to remove the clip from the light in any event. You could also reduce the "stick out" of the point (bend it flatter) if you think it will continue to be a problem. If it looks like a total loss or would like some off-line advice please email me.
Curious, did the light come out of your pocket? I actually intend the clips to bend...which may be misguided on my part...but I generally feel it's better for the clip to fail before it destroys something else like the upholstery on your (or someone else's) seat. Right now I'm looking at 4 other pocket clips on my desk and the angle on the tip is much more conservative. Do you guys think I should put less bend on it to reduce the snagging hazard?
