tobrien
have you given any thought to a possible deep carry version?
Tried one on my SF Fury, and the O-ring squeezes out between the body of the light and the clip. If I unscrew the tailcap to prevent this, the clip is too loose. Any tricks to prevent this?
Here is what I did for the perfect clip set-up: install clip followed by SF lanyard ring then add a Triad Tail-Cap from Oveready with a paracord lanyard and some kind of cool bead!
Dude, will you make us the lanyard ring, please?
This works and looks great, no O-rings needed!
I am glad I found this thread. I was wondering how the pocket clip would fit my G2 and found the picture in this thread. The clip is expensive, but it looks like it will work better then the Solarforce clip I was considering.
I use one of your clips on a Surefire 6P with an Oveready McClicky upgrade, and it's my edc light,and no problems with mine fits in my pocket perfect and stays right in place, the cap tightens down perfect. Awesome job on kyhunter1's clip I've see it in person and it's got a real wow factor,great job on it. What about doing a deep carry clip for the Surefire I would like for the clip to let my 6P go down in my pocket just a little bit more like 1/2" more. But no problems with mine it works perfect, with the McClicky set up. Hope this helps. Think about a run of deep carry if you don't mind.
Since this clip will fit a Malkoff Hound Dog / Wildcat, would it suffice to assume that it will fit all the MD2/3/4?
Do I just send Jason an email with an order?
Glock22 has been in my flashlight case! No, j/k but I have the exact same setup but I am not using the GITD o ring. I am using a unknown sized black o ring from my spares kit. My 6P with Z41 McClicky works just fine and stays in place.
Jason, are these still available?
- JonK
