goldserve
Re: FS: 7 FluPIC JIL DD sandwhiches! Pics!
Ran out of microchips, only 3 left!
onthebeam said:Forgive me if this is a dumb question. Will this also work on the 1.3 UP? I'm leaning toward that light for its brightness advantages over the DD.
Lips said:Does that mean in burst mode the Jil DD with FluPic and RCR123 is brighter or dimmer than a Jill DD without FluPic and with RCR123. (Given Same Bin)
Same question in High Mode.
Geogecko said:Based on what I know, if high is 600mA, and burst is 1A, then both of those levels should be much brighter than a JIL DD without FLuPIC. Not the case, when using a primary CR2 though, it will be dimmer with that.
Lips said:If the above is correct and both versions (with FluPic and without FluPic and both DD using RCR2's) does the Flupic version have greater heat problems than a stock Jil on RCR2's
