Both of these have nitrolon heads and glass lenses.
Top is a G2L. Bottom, an incan from circa 2014.
I ran P91 in my G2 briefly (i think a few days) before switching to the IMR-9 which later switched to HO-9. Now only run P91 in G3 and C3 with 2x17500. You can order spare UCL lens for your G2 from LF too. I ordered from Flashlightlens when I started out (also bought some from Illumination Supply, Craig) not knowing that I can't and don't know how to replace my old G2 lens... newer version of G2 bezel uses the screw on bezel ring to retain the lens in place. Also, I ordered the wrong lens, it's too thick... probably meant for 6PI thought I read something about not a good idea to run the p91 in this format. Can't remember what it was tho.
Just make sure you have the bezel that unscrews before you spend money on the lens.Lumens factory for the lens, dunno about O rings.
P
Good spot! Is there any way to get the press fit ones out?
P
I have heard the trick is to put the lense on the bezel then lay some cloth like a shirt on top of it. Then take a dime and work your way around the edges on top of the cloth. Probably don't use that much pressure or get that close to the edge. It should pop in all the way around.
