Re: MY GLADIUS NIGHT OPS SEOULED(P4)
GLADIUSX1 said:
One of my favorite features of the Gladius is how low and directional the beam is on low level.
While I like what you have done with the high end brightness of the light, the wider and brighter Low kills one of my favorite features of the light.)
The statement is not all that correct. the low is only a fraction higher(1,0 lume instead of 0.8) and the beam is twice as wide over all,so the beam ends up having the same precieved brightness.this is very low and has better beam
quality and is more usefull when reading maps and text,same level, wider beam more usefull.softer edges .
Here are two photos to show the beam at 10-12 inches away.the brighter one is over exposed 1 f stop the other is normal.click on for larger version
Let me first say that I think your mod is nice and well executed for you as a Gladius owner.
If you were a Night-Ops product tester I would say that you have killed one of the best features of this light.
There is a SIGNIFICANT difference between .8 lumen and 1 lumen at that level.
It is a 20% increase of total light output.
Your pictures demonstrate this very clearly.
Look in the low right corner of your photos.
On my 17" Powerbook-
Gladius stock - no door casing visible
Gladius P4 - door casing clearly visible and the entire wall around the corona is brighter.
That kills one of my main uses for my Gladiuses. Illuminating a small area while not illuminating the rest of a room. I like using my Gladiuses on low when looking for things in the bedroom knowing
1. I can see fine.
2. I have such control over it's beam and how the room lights up I never need to worry about disturbing my wife.
My first year at MBC my roomate was from New York and I am from So. Cal., with my Gladius I could negotiate the room without him ever waking up.
Out of my lights, only my Red Raw on low works better in these circumstances. On high it is 190 lumens of truly blinding RED light.
I have plenty of lights that will blow away a Gladius for overall brightness.
It is my only light that combines good useable brightness with the ability to go VERY low in light output.
You may want to mention that modding the lights will also void their warranties.
If you are a private person and this mod works for you, then great.
If others would like to have you do this and do not care about voided warranties, great again.
I am just saying that when and if Night-Ops revises the Gladius I hope they DO NOT loose the current low setting. I feel the Gladius will loose some of its funtionality without having the circuitry adjusted to keep the low as low as it is now. For that matter with the wider beam I would like to see a new Gladius with a low level at .6 lumen.
These are just my opinions based on how CLEARLY your photos demonstrate how much brighter the extra .2 lumens is in your mod.
Take Care,
mtbkndad :wave:
