tripplec
Ahh, ok makes more sense as some applications are high current. A couple of amps in two way radios for one example when transmitting. They should take a good input current without issue. I've not run into in my charging either. Total mA in the cycle is close to the spec where the cells were low.My assumption is that that is charging protocol if you have a dumb charger, you just set a timer for 16 hours and then remove the cells. I have been treating them like any other NiMH and charging them at 1000mA on my C9000 with no obvious issues.
Thx
