Marduke
Re: Initial charge on Eneloops, charging strategies. (AAA)
That is NOT correct. Both "test" and "refresh" show discharge capacities. Only the discharge mode shows "accumulated" capacity.
Sorry if this has been mentioned, because I haven't read the next two pages of posts. "Test" on the LaCrosse will only dispay discharge capacity while discharging. As soon as it begins the next charge cycle, the discharge capacity is erased and "accumulated" capacity is displayed. So unless you are right there at the charger observing the discharge current as the voltage hits 0.9 volts, the displayed "capacity" of the cell at end of test is not the discharge current, but the accumulated capacity. The only mode on the LaCrosse which retains the discharge capacity in the display during the subsequent charge is refresh mode. Just wait for it to go to charge, note the discharge capacity, then if you don't want another refresh cycle, simply unplug and plug back in the wall wart and set your charge rate.
