Dan did an awesome job running with the initial suggestion i had for eliminating the bezel groove. I had suggested a solution that would have had to be re-designed, but he knew what i meant and solved it in an extremely elegant way w/o having to start from scratch. Look at the 'before' bezel on the bottom light vs the 'after' bezel on the top light.. invisible seam, i love it... 'how the heck did he do that'.. when you get yours you'll be like 'duh'.. why didn't anybody do that before?
I have a design to hide the body seam as well, but it introduces manufacturing hiccups, so i guess we get one seam.. always something to look forward to in the next generation. I really love the way this light is coming out.. the tail cap is now a perfect match to the head, yet since the head is wider, you can't mix it up in your pocket. Brilliant design guys.
I saw that somebody mentioned solving the lanyard hole in a method other than tying a knot in the lanyard so it won't pull through the hole.. I think it's being seriously looked into... I had a suggestion of putting two holes 'toed in' to each other so that either a cord or even a split-ring could be fished through.
ps,. how'd you put grooves in at the tail? doesn't look like there is enough 'meat' in the metal.. or is that past the battery and just where the threads for the kroll are? genius i love it.
-awr
